06-26-2018 09:36
06-26-2018 09:36
Is there any way I can disable the bottom right button while I'm exercising? I unwillingly press it, especially while biking, but also during weight training. This ends up screwing with the stats.
It really is a pain, especially for a device developed for exercising and training.
06-26-2018 10:26
06-26-2018 10:26
Same, cycling especially. Following...
06-26-2018 11:55
07-17-2018 15:19
07-17-2018 15:19
This has to happen or I'll probably get rid of my Versa. No point in using it during exercises if it's paused every time I look down.
07-18-2018 02:33
07-18-2018 02:33
I have the same issue especially during workout with weights.
Very annoying...
08-01-2018 07:10
08-01-2018 07:10
Same! I was hoping to find a solution. Anyone had any luck yet?
01-13-2019 22:08
01-13-2019 22:08
Easily the biggest painpoint. While weight training, I have to rotate the watch and even that isn't failproof. Nike has a lock option. Hope to see this in the next app update.
01-13-2019 23:15 - edited 01-13-2019 23:16
I thought I was the only one! This is a major design flaw with an easy fix. I doubt they will fix it though. I have seen posts for a find my phone app from years ago and has never been implemented. This is my first Fitbit let’s see if they are as good as I hope them to be.
09-13-2019 19:38
09-13-2019 19:38
This is a common complaint and has been a long time with no attempt to fix it by Fitbit. Sadly, the wife and I have come to the conclusion that the only real fix is to move on to another brand. Pretty sad really, I'm sure it's a simple fix to add an enable/disable feature in settings.
09-15-2019 07:48
09-15-2019 07:48
I am also very disapointed that my comment hasn't even received basic acknowlegement from the Fitbit support team, let alone a fix. I will also be moving on to another brand, as soon as Summer exercise season is over.
09-15-2019 14:46
09-15-2019 14:46
Seems that they are rolling this feature into the upcoming Versa 2, which doesn't have any buttons on the right side. Checkout their product page:
What that means for us consumers is that we'll have to drop another $200 to upgrade to a new device.
09-15-2019 15:02
09-15-2019 15:02
Right, so their answer isn’t a simple software upgrade to disable the button in settings but rather for us to throw in the trash the $200 “latest” model and replace it with the 2nd generation coming soon? No thanks.
