01-02-2022
10:52
20:40
01-02-2022
10:52
20:40
I have my distance set at 4 miles but I have to walk almost 6 1/2 miles before it turns green on my app. Is there some way to fix it?
01-27-2022 09:39 - edited 01-27-2022 09:40
I would check your distance settings and. Goals @linlit
4 miles is 6.437 kilometers
Best Answer01-28-2022 23:52
01-28-2022 23:52
There seems to be a long term conversion bug in the app. This prevents the goal ring from corresponding to the set goal (miles), but instead it seems the goal is converted to kilometres and the ring instead relates to that.
