Does Versa have a stopwatch function?
ANSWERED
Long time listener; first time caller.
Moderator edit: subject
1 BEST ANSWER
Accepted Solutions
@fitbart Yes, it does. It's the app called Timer on your Versa that offers both Countdown and Stopwatch functionalities.
Marrrmaduke | Canada
Charge HR, Blaze, Charge 2, Charge 3, Inspire HR, Versa Lite, Versa SE, Aria
8 REPLIES 8
Hey @fitbart, welcome to the Community and @Marrrmaduke thanks for stopping by.
I am glad to see here that our friend replied your inquiry. If there is anything else we can do for you, do not hesitate to post it.
Keep the stepping up! Man Happy
My stopwatch changed from a traditional stopwatch to a countdown watch and I have no idea why? How can I change it back to the traditional stopwatch?
Mine has done the same, irritatingly at the end of a run when I was on target for a PB.  No idea how to restore it to stopwatch
@hst1984 and @RaySul -
When in the Stopwatch/Timer app swipe left or right to change its function- you will see the "underline" under the icons switch from one to the other, as well.
RETIRED Enterprise Computing / "IT Guy" - Southern California - Marine Staff Sergeant 1970-78
Apple Watch 6 - iPhone 8 (iOS 16.7.8) - FitBit app 4.20 - MacBook Air (macOS Catalina)
It's a bit counter intuitive, but to change between countdown to stopwatch swipe left to right on the screen, swipe the other way to revert to countdown.
How do I turn the stopwatch off?
Hi @ValerieDuda  - if you use the SimpleTlimer app you can start and pause the stopwatch using the button which is more intuitive.
To exit you double-click the counter. It has many other neat functions.
