My old FB used to sync my steps with MFP. Also, unless Im confused 😳 I think MFP used to sync foods into FB as well. Anyone else know of anything?
Also, STILL have trouble with my sleep syncing.
I have a Fitbit Versa and and Android. Any help is appreciated!
@AGBritton Welcome to the Fitbit Community! I hope you're doing well! Thank you for your inquiry. You can follow these instructions to link both accounts. You can then check this article to understand how the integration works.
Regarding sleep detection your device will start recording sleep after it detects an hour of inactivity. If you have a light sleep or move too much then this may difficult your sleep detection. Additionally you can try wearing your device on your non dominant hand to decrease the amount of movement it is subjected to. Finally you can restart your device. You can also manually log your sleep time.
Let me know how it goes.
@TamGate I hope you are doing fine and sorry for the late reply Thank you for sharing your experience with the MFP integration as it help to know it is working for other users.
I'll be around.
