03-27-2019 05:17
03-27-2019 05:17
Hi!
i reed that "FITBIT VERSA" Does not work properly with
Huawei Mate 10 Pro / Android 8. Is this fixed?
03-27-2019 12:22
03-27-2019 12:22
Nope, the 20Pro is supported by Fitbit, see www.fitbit.com/devices and type Huawei.
Best Answer03-27-2019 11:27 - edited 03-27-2019 11:33
Hi, it's not an android problem. This is the statement of fitbit itself: "Due to Bluetooth issues that prevent certain devices, like Fitbit devices, from syncing, our products aren't compatible with the following phones" , one of these phones is the one you mention. However there seems to be a fix for that, see: https://www.reddit.com/r/fitbit/comments/abk4xh/huawei_sync_fix/. Don't know if it works or not.
Best Answer03-27-2019 12:02
03-27-2019 12:02
Thanx for your reply.
I dont have this Phone, But read it in a review.
I have Huawei p20 pro. That one, also in the list?
Best Answer03-27-2019 12:22
03-27-2019 12:22
