03-21-2018 11:27 - last edited on 10-22-2021 16:18 by LiliyaFitbit
Will the Versa have a an app supporting Duo Mobile for Multi-factor authentication? I've been a FitBit customer for years and I love the FitBit app on my phone, but my colleagues who have Apple Watches that they can tap to let them MFA are tempting me big time.
Short of Duo Mobile support on the versa, I would GLADLY PAY for a version of the Fitbit App for IOS if it would support the Apple Watch (as opposed to only FitBit bands).
03-21-2018 14:23
03-21-2018 14:23
Welcome to the Fitbit Community Forums! @SunsetRunner ![]()
I can totally see how useful MFA would be on Versa. At this time, Duo Mobile won't be one of the apps available, but stay tuned to see what other apps are added down the line.
03-21-2018 14:23
03-21-2018 14:23
10-12-2018 11:22
10-12-2018 11:22
Is there any way we can convince you to make an app for Duo Login?
10-18-2018 08:56
10-18-2018 08:56
Fitbit apps are mostly created by the community. Someone at DUO or a highly motivated user would need to develop this.
09-22-2019 18:36
09-22-2019 18:36
Any update on this? it would be super useful
04-10-2020 06:21
04-10-2020 06:21
This is working on my Versa 2. Sort of.
I enabled notifications for the DUO app and I get two notifications.
I tap the second notification to open it. Then tap on "Tap To View Actions"
It will bring you back to the clock. .
Swiped down from the top of the screen to return to your notifications.
Tap on the second notification to open it. Then tap on "Tap To View Actions"
Your MFA has been confirmed.
If you don't want to confirm, just ignore the notifications and let it time out.
Two notifications
After tapping the second notification
06-12-2020 05:34
06-12-2020 05:34
I use this option as well, kind of clunky since ther is no "approve or deny" and that you have to click tap to view actions then reswipe and tap that again, but it works
07-01-2020 12:03
07-01-2020 12:03
is this with android phone paired versa? coz with my iphone paired, I dont see the same screen. Is there an app or so?
05-24-2021 11:12
05-24-2021 11:12
Interesting, I have a Versa 2 and an Android phone. I don't get DUO push notifications on my Versa (even I enabled DUO notifications on my Versa). But I can get DUO phone calls notifications, useless because I can only accept or reject the cal, and then I have to take my phone to hit a key to authorize DUO...
Best Answer07-23-2021 07:13
07-23-2021 07:13
This is clumsy af, but it does indeed work! Android (s20) & sense user here. I have to auth with duo no less than 5 times on a good day, so any progress here is good. I really hope they get this working with a single "button" click.
Best Answer07-23-2021 11:58
07-23-2021 11:58
Best Answer10-19-2021 03:24
10-19-2021 03:24
Seems that this at least for me no longer works since the latest duo app update
10-19-2021 04:20
10-19-2021 04:20
Nope. I hadn't tried it since the update, but I just did and got a timeout after doing the double tap to view options. When I looked at my phone, it was asking me it this was a suspicious login. So I tried again, with my phone unlocked/screen on, and same thing. Wondering now if it has some sort of "allow list" you could add the fitbit to.
Best Answer10-19-2021 05:14
10-19-2021 05:14
I confirm that with the latest update of the duo app, "double approval" has stopped working
10-19-2021 05:39
10-19-2021 05:39
Looking a little closer at this, I think the fitbit is now sending a DENY rather than approve. The "suspicious login" message, is apparently what you would get on a deny according to the docs here https://guide.duo.com/android#push
10-19-2021 08:07
10-19-2021 08:07
Best Answer10-19-2021 11:32
10-19-2021 11:32
Yes this was working fine but they switch the order of operations. Which makes it impossible to accept. If the Fitbit would display both options this would be the best solution and would help with other notifications and not be a specific feature for ONLY duo users. I always thought it was strange that it did not give you a way to deny the option. FITBIT/ GOOGLE please add the ability to show all notification options to allow for better notification interactions.
10-19-2021 11:35
10-19-2021 11:35
Best Answer10-19-2021 11:37
10-19-2021 11:37
do you mean Microsoft authenticator shows an accept/deny option?
Best Answer10-19-2021 13:00
10-19-2021 13:00
