05-18-2018 09:27
05-18-2018 09:27
I forgot to stop logging my time on my mat today in the yoga studion. How can I edit the time logged on my mat?
Best Answer05-19-2018 07:42
05-19-2018 07:42
Fitbit does not allow an editing of the time. if it bothers you the only course of action would be to delete and manually record the mat time.
05-19-2018 07:42
05-19-2018 07:42
05-19-2018 09:28
05-19-2018 09:30
05-19-2018 09:30
Best Answer05-19-2018 09:33
05-19-2018 09:33
Yes, if it is running the Windows 10 Fitbit app. If you click on the Yoga entry, there will be a pencil icon in the upper right corner. Select that, and you can change the start or stop times for the activity. I often forget to stop workouts, so this feature (which isn't documented) is a lifesaver. Best of luck.
05-19-2018 09:35
05-19-2018 09:35
Best Answer05-19-2018 10:03
05-19-2018 10:21
05-19-2018 10:21
Best Answer05-19-2018 11:20
05-19-2018 11:20
Are you using the web browser? This will not work, the Win 10 app on a Win 10 computer must be used.
I had forgotten about this option.
05-20-2018 05:54
05-20-2018 05:54
Best Answer06-08-2018 06:08
06-08-2018 06:08
Surely this is ridiculous. Fitbit, can we please have this option everywhere? What's the point of not being able to update time or distance? Like now I have a workout in a static bike with distance zero. Already tempted to return the watch
