Hi, do you still have the "old" Firmware Version (.19) or on the newest (.30). You can check that by going to the settings on your Versa and scroll all the way down to Device Info and press it. It's important to know as the answer to your question will be different for these versions.
Best AnswerHi, you probably mean .30 version. This one logs your sleep automatically and after syncing it with your
Fitbit app, it should appear on your Fitbit's dashboard. At least that it does with me. In the former version I had to enter in manually in orer to be synced to my Fitbit app. Please explain the "erasing" further, cause in principle this it not possible cause it's kept and saved on the Fitbit Servers.
