02-07-2020 19:33
02-07-2020 19:33
My face clock on my vera lite disappeared two days ago. I no longer see it available so I tried to get another one but it will not let me, times out then says try again later. Anyone else had this issue or know how fix it? It seems to be a software issue
02-10-2020 13:00
02-10-2020 13:00
I noticed last night that the clock face it gone... can't seem to figure out what the problem is.
02-08-2020 07:02
02-08-2020 07:02
is this what you mean?, if so... yes. And I posted about it here which has since been deleted.
02-10-2020 13:00
02-10-2020 13:00
02-10-2020 14:18
02-10-2020 14:18
mine's also completely gone since this morning
02-10-2020 14:27
02-10-2020 14:27
so, I called fitbit about it and the solution to reset the Versa is ... hold down all the buttons at the same time for 12 seconds, then release the bottom right button and continue to hold for 10 seconds. That should fix it. Apparently, holding down the buttons at the same time is how you reset the Versa.. who knew?!?!
02-10-2020 14:36
02-10-2020 14:36
I'm also not able to sync from the app either
02-10-2020 14:38
02-10-2020 14:38
wow! That worked! Thanks so much. Although mine does not have a bottom right button. really, who knew? What a great community to be a part of! 🙂
12-11-2020 12:08
12-11-2020 12:08
Excellent ! Thank you
02-15-2021 06:07 - edited 02-15-2021 06:08
And that fixed it! Thank you so much for posting the solution!! Mine was totally gone.. I only saw black instead of a clock.
04-30-2021 13:00
04-30-2021 13:00
Thank you!
05-05-2021 14:52
05-05-2021 14:52
So this worked the first time this happened about six months ago, but here I am again and it isn’t fixing it at all this time. Any ideas??
06-15-2021 11:48
06-15-2021 11:48
Fitbit
08-11-2021 05:45
08-11-2021 05:45
this worked for my Versa 2 - just one button to hold.
Crazy but thanks for the help!!
01-26-2022 09:44
01-26-2022 09:44
Hi
thanks for that. I only have one button on the left but I held it down and it reset! Simple! Thanks again
Marg The Kiwi
04-13-2022 16:06
04-13-2022 16:06
My clock face disappeared from my sense. I held down the power button for about 12 seconds. My sense restarted and clock face reappeared.
06-26-2023 11:49
06-26-2023 11:49
The problem is more complicated than that. The clock, the actual numbers, disappear from the clock face, and only comes back, for a while, after doing a reset, then you have to reset again!?
