10-29-2019 19:14
10-29-2019 19:14
I recently purchased my Versa. After only wearing in for a few days I noticed it wouldn't sync. I would manually sync & got a message on my phone that the "device could not be found". I tried turning the device off then ba k on, also turned off bluetooth & back on, it would not find the device. I tried a factory reset, but now my screen only shows a big red X & says "Data Not Cleared. Sync & try again." I can't sync because my phone cant find it via bluetooth, therefore, the app doesn't see it to sync. Not sure where to go from here, any help would be appreciated.
Best Answer10-30-2019 05:08
10-30-2019 05:08
UPDATE: I was able to get everything to work (including the sync) by adding the Versa as a device in the app for a second time. I just chose to "replace" the original device when it prompted me. It went through the whole set up process again, including the software update, and now it works fine.
Best Answer10-29-2019 19:53
10-29-2019 19:53
I had the EXACT same issue in August. I contacted customer support and they sent a replacement watch.
Best Answer10-30-2019 02:38
10-30-2019 02:38
I would do a search, i noticed several threads have been marked as having an answer.
10-30-2019 05:08
Best Answer10-30-2019 10:34
10-30-2019 10:34
I am having the EXACT problem that you are. But when I am trying to replace my versa lite in the app, it still can not find it. I have restarted my phone, turned off and on the Bluetooth.....nothing!! I have only had this fitbit for a few months, so this is frustrating.
Best Answer10-30-2019 21:09
10-30-2019 21:09
How many times have you tried adding the Versa @Mgreen8504?
