04-01-2020 10:52
04-01-2020 10:52
Versa was not syncing correctly so restarted phone but no joy so went to settings on phone and selected shutdown. Now unable to restart watch. Have tried the 3 button reset but nothing happens. Phone is fully charged .
Please help.
04-01-2020 11:01
04-01-2020 11:01
@Pigsy Rub the contacts with an alcohol and try charging for several hours. Then you can attempt hard reset using buttons:
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear. This may take a while.
You can set up the watch back to the Fitbit account by following the instructions on this link: How do I set up my Fitbit device?
If you're not successful with the factory reset, I am afraid you will need to reach out to Customer Support to guide you through the next steps. Here's the link to Customer Support page.
04-01-2020 11:01
04-01-2020 11:01
