05-27-2019
00:44
07:16
JuanJoFitbit
05-27-2019
00:44
07:16
JuanJoFitbit
My Fit bit Versa has stopped working suddenly inspite of being completely charged .
Tried holding all 3 buttons for 15 secs - occasionally vibrates but nothing on the screen.
Recharged it again for 4 hours, no change.
Fit bit has just stopped working.
any suggestions plz
That try of a restart is not the right procedure. To restart a versa press and hold the back and bottom buttons until you see the Fitbit logo on the screen.
If that doesn't help then it's probably best to contact customer support. If they can't fix it then they can check your warranty status and advise on your options: contact.fitbit.com
@PRBA welcome to our Fitbit Community! I'm happy to assist you with with the charging issues that your Versa is experiencing. By the way, thank you for troubleshooting this issue before contacting our forums.
I'd like you to try the troubleshooting steps that are listed in this help article. This article also contains the restart process but you can skip it since you already tried it.
Thank you for your help my friend @SteveH!
Keep @SteveH and me posted on the outcome! ![]()
