02-19-2019 16:18
02-19-2019 16:18
One morning I got up and it had the wrong time on it went to reset it and now it's just showing nothing but the icon for fit bit nothing else is coming on. But it is fully charged
Best Answer02-19-2019 16:52
02-19-2019 16:52
Doa Restart and do it several times if necessary and then sync it to update the time.
Best Answer02-19-2019 17:04
02-19-2019 17:04
I can't reset I can't get on the apps on the watch to reset only thing it shows is the fit bit icon and some words scrolling underneath
Best Answer02-19-2019 18:37
02-19-2019 18:37
It looks like the Versa suddenly did a factory reset (not sure how). The words you see are probably saying Hello in multiple language and inviting you to pair it.
You should open your Fitbit app on your Smartphone, delete your Versa on your account and try to make again the initial setup.
Best Answer02-19-2019 19:33 - edited 02-19-2019 19:34
How about try the reSTART rather than reSET, like cbwilsha suggested. Hold left and bottom right buttons until it restarts, a couple times. I'd try that before anything else.
Best Answer02-19-2019 19:36
02-19-2019 19:36
And if the clock time was wrong, I'd try syncing. You reset to factory settings if the time is wrong?
