02-27-2019 04:11 - edited 02-27-2019 05:27
My fitibit versa started to press automatically its upper right button, opening the notification bar and the running section.
When I'm exercising it keeps trying to cancel it, and also it keeps vibrating on my wrist, I'm already taking it off because I can't sleep wearing it.
Heres a video of the issue: https://gfycat.com/anxiousthriftyfrogmouth
Already contacted support, does anyone have this issue?
03-07-2019 03:25
03-07-2019 03:25
I have contacted support and they sent me a voucher to choose between a new one or discount in another product.
Thank you all.
02-27-2019 04:54
02-27-2019 04:54
Hi, the link does not work.
02-27-2019 05:25
02-27-2019 05:29
02-27-2019 05:29
Thanks for prompt reaction. Try restarting your Versa several times in a row, by pressing and holding the left and right lower buttons together untill you see the Fitbit logoand release the buttons. Hope this solves this very strange issue. Good luck!!
02-27-2019 07:54
02-27-2019 07:54
Thank you @SunsetRunner .
But the issue's still here.
I appreciate your help
02-27-2019 09:29
02-27-2019 09:29
Update: Did a factory reset, and the issue persists.
02-27-2019 09:53
02-27-2019 09:53
Hi, the it's time to contact Customer Service with this weird issue.
02-27-2019 09:55
02-27-2019 09:55
Already done, sent an e-mail and the video with the issue.
But they doesn't have support here in Brazil, wondering how they would fix it.
02-27-2019 10:01
02-27-2019 10:01
Hi, I will contact a Moderator to have a look into this.
02-27-2019 11:54
02-27-2019 11:54
Okay @SunsetRunner , Thank you for your help.
03-07-2019 03:25
03-07-2019 03:25
Thank you all.
