My Fitbit Versa screen has been really dull and unresponsive for about 12hrs now. It won’t let me swipe to a different screen or change settings. It still tracks everything as normal although it’s almost impossible to read due to the light being so low. I tried charging, restarting and everything else the forums says but no luck. It seems like the screen gets brighter initially when I restart it but goes right back to being dull.. please help!
@AdrianDevkaran Thank you for getting back. Despite the charging issues that your Versa experienced, I'm so glad to hear that you will receive a replacement unit. Thank you for posting the update.
I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community more often! ![]()
Hi, are you using a Third Party Clock Face? If yes, change it to one developed by Fitbit itself and restart your Versa. If you're using a Fitbit one, restart your Versa 4-6 times in a row by pressing the left and right lower buttons together untill you see the Fitbit logo and release the buttons. This will reset the internal system of your Versa.
Hi Adrian, contact Customer Support about this issue, cause normally when you switch form a Third Party Clock Face to one of Fitbit, the problems are solved. It seems you have a more serious problem.
Best AnswerHi Adrian,
if your contact leads to a replacement of your Versa, see my signature. Thanks,
@AdrianDevkaran It's great to see you in our Fitbit Community! I'm happy to assist you with your Fitbit Versa since its display is not working properly. By the way, thank you for trying the troubleshooting steps that shared @SunsetRunner.
I was able to get in touch with our Support team and was told that they assisted you via chat. Was a solution provided?
Looking forward to your response! ![]()
This same thing happened to me. The fix worked the first time, but not the second. It is unresponsive completely. Was told I'd have to purchase new one. Was sent a 35% off code. Went to use it but the versa 2 is on sale so code won't work. Thought this to be fairly poor customer service, considering all replacements I have required.
