07-10-2018 16:57
07-10-2018 16:57
The last couple of days, my iPhone 7plus battery has been draining very quickly. I have an appointment with Apple, but I also looked at the battery usage app. Aside from CNN, the Fitbit App is using the most battery on my phone, at 12%. But that breaks down to 19 minutes screen and 37 minutes background! What's going on! I have all day sync turned off and most of the push notifications and emails as well. 37 minutes? What is the app doing in the background for 37 minutes?
Anyone else having this problem?
Best Answer07-10-2018 17:05 - edited 07-10-2018 17:07
No, I'm not experiencing this problem... The app has spent 17 minutes on screen and 1.2 hours in the background..draining only 3%... Are you running iOS 11.4?
Edit: For better help, there's also a Fitbit app iOS forum.
07-10-2018 17:30 - last edited on 10-03-2019 13:28 by LiliyaFitbit
I’m just installing it now.
I’ll see if it makes a difference.
Regards,
Best Answer07-10-2018 17:33 - edited 07-10-2018 17:42
On the Android side the Fitbit app was causing excessive data network use and battery draining problems. Fitbit released an update Fitbit app today, I presume for Android only. Check out the threads in this forum for more details. Maybe the iOS Fitbit app has a similar bug?
See this ... https://community.fitbit.com/t5/Android-App/Android-app-version-2-74-1-is-now-available-7-9/m-p/2189...
Best Answer07-11-2018 00:27
Bronze Community Members are highly active users who have shared their knowledge for the betterment of Fitbit products and services. Learn more
07-11-2018 00:27
There's an iOS battery drain bug in 11.4 (and maybe 11.4.1 too?), causes as of yet unknown, maybe it's that. I find the battery usage app fairly unreliable, and it mostly shows completely useless information even when it's accurate. Your fitbit battery usage looks normal either way.
Best Answer07-23-2018 14:14
07-23-2018 14:14
I was wondering if you had installed iOS 11.4 ... not trying to get you to install it because of said battery issues.
