05-06-2018 05:27
05-06-2018 05:27
Has anyone else been able to successfully add their Amex cc to their Wallet? I've added two other credit cards with no issue (different banks). Amex addition continually gives me this error message. Contact to Support has offered no insight.
Best Answer05-06-2018 10:40
05-06-2018 10:40
I found a thread on the Ionic forum discussing this. Apparently to add an Amex card, the phone wifi needs to be off sending the request through your cellular network. Once I did this it worked like a charm. Thanks for your suggestion anyway.
05-06-2018 09:54
05-06-2018 09:54
That's odd. AmEx is in the list of supporting banks. By chance do you have two step authentication enabled with AmEx? You might get a little more insight if you asked AmEx as I am sure if there is a problem they would already have heard about it.
05-06-2018 10:40
05-06-2018 10:40
05-19-2018 13:12
05-19-2018 13:12
Sounds bizarre, but after reading this solution I tried it, and indeed trying with the cellular data worked with the WIFI off! Thanks!
Best Answer12-29-2019 13:49
12-29-2019 13:49
not working for me:(
02-02-2022 09:48
02-02-2022 09:48
Not working for me either but my error message says they don’t support the card
05-03-2022 04:27
05-03-2022 04:27
Not working for me either. Has anybody found a solution for Charge 2?
Best Answer08-29-2022 12:20 - edited 08-29-2022 12:20
Not working here. Two calls to Amex support, they say it's definitely a fitbit issue. They even verified the card on their end, and Amex now says the card is ready to go for Fitbit Pay on their end. But Fitbit Wallet still says inactive, need to verify. Endless loop. I give up.
Best Answer10-11-2022 04:36
10-11-2022 04:36
I'm having this exact same issue. Did you ever find a resolution? I've been on the phone with both the bank and fitbit repeatedly for weeks and nothing.
10-11-2022 06:08
10-11-2022 06:08
