01-08-2022 12:03
01-08-2022 12:03
The app Fitbit Tips is broken. It is stuck on the first screen that says "Shortcut". I cannot move past from it.
01-08-2022 22:48
01-08-2022 22:48
Hi @MarcoGalleg - Are you able to restart the device?
Best Answer01-09-2022 10:26
01-09-2022 10:26
Yes I am why?
Best Answer01-09-2022 10:32
01-09-2022 10:32
@MarcoGalleg - does it fix the problem when you restart?
Settings, About, Shutdown - then wait 10 seconds and place on the charger to restart and charge it.
Best Answer01-10-2022 06:12
01-10-2022 06:12
Nope I think that it is a problem with the app
