11-09-2022
16:32
12:55
LucioFitbit
11-09-2022
16:32
12:55
LucioFitbit
My new fitbit 2 is not responding to alexa call or text request. Is there something I have not set up correctly? I purchased from HSN and they showed msg and calls on the versa 2. On my former versa 2 it showed up that I had a msg or call. Can someone plz advise.
Hi there @Subpcm, it's good to see you around in the Community.
Thank you for this information. I'd recommend you check this article, How do I use a voice assistant on my Fitbit smartwatch?.
Hope this helps.
