Anyone recently had issues logging % body fat?
Used to be able to log in 0.1% increments.
As of about 2 weeks ago, can only do in 1.0% increments
Not letting me log more finite values.
Let me know and if you know how to fix this.
Thanks
Joe
Hello @josephbershad and a warm welcome. To the best of my knowledge, the place where you can log % Body Fat is on the app. You can only log weight on the Versa 2 itself. That said, if you are an iPhone user, this is a known problem and Fitbit is trying to fix it. A moderator suggested entering your information on your web (fitbit.com) dashboard until it is fixed. Cumbersome, but a workaround.
Laurie | Maryland
Best AnswerThanks for the web based suggestion
Will give that a try til the app gets fixed
happy holidays
Best AnswerI have also had this issue. I have logged my weight nearly everyday since March but I have never gotten a body fat reading. On the app it just shows - -% and the scale only has the number for the weight.
I am using an iPhone so perhaps it’s a software issue but it really should be compatible at this point.
