Hi all! How can I find the Versa 2 default clock face and install it on my Versa?
I couldn't find it in the gallery and I'm really disappointed because the display size looks to be the same, will it be available for Versa and Versa Lite?
Isn't that "Waveform" I see in Versa 2 gallery "By Fitbit" though maybe icon colors not quite the same unless they are adjustable?
@kansas_m wrote:Looks like they don't care about this... I created my own clock face, Waveform Vectors
I did respond and asked you a question but you did not answer, so I could just as well say, 'looks like you don't care.'
It wasn't obvious you answered as a Fitbit employee, your profile looks more like a random customer, maybe a fitbit icon instead of an avatar will help, or a description, idk. I didn't say anything because I didn't want to polute the thread guessing things with someone who was looking like a customer.
Since you are a Fitbit representative, I expected you to tell me if it's Waveforms or not, I guess it is, if you ask me.
The main question remains unanswered, will it be available for Versa as well? When?
I don't see any reason why it's only available for Versa 2, because Versa and Versa light have almost the same specs, at least the display is the same and the clock face doesn't require changes to be rendered properly on these 2 older devices from my pow.
Best AnswerMy apologies. I now see your issue was that clock face was not available for the original Versa. I missed the distinction between Versa 2 and Versa - my bad.
I am not a Fitbit employee. I just thought I had answered your Q, but I see now I hadn't.
Just downloaded Waveform Vector, love it! Is it possible to add colors alternatives? Would love to change the yellow to blue or pink..
Agreed! Would love to see that as a feature as well.
Best AnswerI downloaded it too but it won’t stay. It reverts to what u had before
Best AnswerHI, Do you plan to open source your code? I want to make some changes and really appreciate if I can use your work as base work.
Best AnswerThe "waveform" version is the default clock face for the versa 2.
