05-03-2021
23:34
07:32
05-03-2021
23:34
07:32
Can the battery be replaced on the versa 2
05-04-2021 07:32 - edited 03-18-2024 09:02
Hi there, @JackieGoud. Welcome to the Community Forums.
Please note that the battery on your Versa 2 is not replaceable nor interchanged. We as Fitbit do not do it or suggest to do so as it could permanently damage your watch.
Keep in mind that your Versa 2 was designed to last 6+ days, but this also depends on how frequently you use all the features of your watch. Said that, I recommend charging your Fitbit watch with a USB port from a computer or a UL-certified outlet into the wall and then turn off all the features that you don’t use that much.
After following the above suggestion, please check this help article for more tips and recommendations.
Hope that helps.
Hope that helps.
