What is the recommended USB wall charger for Fitbit Versa Lite. Please define specs that is recommended by the company.
I'm not sure there is a recommended spec. The only thing I have seen from Fitbit is:
"Plug the charging cable into a USB port on your computer, a UL-certified USB wall charger, or another low-energy device"
Taken from: https://help.fitbit.com/articles/en_US/Help_article/1799/ with the same text in the Versa Lite manual
I think the "UL-certified" is just a safety standard and that the fitbit will just take the power it needs so any spec charger will be ok.
Best AnswerHi Steve,
I have gone through the article for charging fitibit, the reason I am asking for the specs of the wall charger due to the fact as the company is stating to charge it with "low energy charging device".
Some wall chargers are throwing off higher amps [compatible with fast charging] and some throws off low amps.
If fitbit Inc. is able provide a set guideline i.e. any company's brand charger, it would enhance the battery life of fitbit.
