10-02-2019
08:15
06:14
JuanJoFitbit
10-02-2019
08:15
06:14
JuanJoFitbit
Tried all troubleshooting methods:
Turned Bluetooth on and off
Turned Fitbit on and off
Factory reset Fitbit
Deleted the app then reinstalled
Removed Fitbit from my account and tried to set it up again
App is updated
Will not let me update the versa lite as it won’t connect device.
keeps saying device not detected. Thought it was because I’m using the iPhone 11 so it’s new and not compatible so I tried syncing with my iPad but still no joy.
Sons Ace 2 syncs perfectly fine so not sure what the issue is with my Fitbit, it’s only a month old
Moderator edit: format
Best Answer10-02-2019 15:18
10-02-2019 15:18
@KNLB2 Delete Versa from your iPhone's bluetooth settings (paired devices), reboot your phone and Versa, open fitbit app and set up Versa again. It should prompt you to pair and link the device.
10-02-2019 15:18
10-02-2019 15:18
10-03-2019 06:05
10-03-2019 06:05
@KNLB2 welcome to our Fitbit Community! Regarding the syncing issues that your Fitbit Versa is experiencing, I'm afraid that the reason may be because the iPhone 11 is not in the Supported devices list. I appreciate the time spent trying the troubleshooting steps you mentioned above.
However, I'd like you to submit a compatibility request in our Feature Suggestions board and people can vote for it. The more votes your request gets, the more chances it will have to be reviewed by our engineers.
I appreciate your patience and understanding with this.
Thank you for your help @Marrrmaduke.
I'll be around if any questions arise.
Best Answer10-05-2019 12:59
10-05-2019 12:59
J ai fait ce que «Marmaduke suggerait (desinstallation et tou)..cependant ma ««versa Lite continue de se mettre a jour depuis 2 heures et ce n est pas encore termine. Est ce normal. Merci de me repondre
Best Answer10-08-2019 09:10
10-08-2019 09:10
@Rachoub Oui. c'est possible via bluetooth.
Best Answer10-09-2019 16:17
10-09-2019 16:17
My Versa Lite has also not been syncing this week. It's very frustrating and my phone has not changed - it's an iPhone 6s, which is a supported device.
Best Answer10-09-2019 19:18
10-09-2019 19:18
@mh22 did you update to ios13?
Best Answer12-26-2019 04:59
12-26-2019 04:59
i already did this and it still won't work
01-14-2020 19:10
01-14-2020 19:10
I havent been able to sync the last 4 days and I don't even have an IPhone! I have a LG G5 and ever sence I got this VLite over the summer it has been having syncing issues but now it just wont aync at all...
Best Answer03-10-2021 05:31
03-10-2021 05:31
Is the iPhone 11 still
unsupported device for your Fitbit versa light? I just got the new iPhone 11 and I’m having the same issues with syncing that was listed in this prior thread.
I have tried deleting the app and reinstalling it, turning on and off Bluetooth, turning on and off the Fitbit. I tried deleting the device to re-add it and I cannot find the phone. Are there any new options for adding to the iPhone 11 at this time?
