08-17-2018 14:07
08-17-2018 14:07
Does Versa have trouble connecting to a AT&T U-verse WPS WiFi? During setup it indicates connecting on my Android but it never competes the connection or pairs up. Any work arounds or do I have to set it up via my desktop PC?
08-17-2018 19:25
08-17-2018 19:25
It is likely not the source but your router. Fitbit only conncect to 2.4Ghz. Suggest you check your router to see if it is 2.4 Ghz, 5Ghz or dual band. If it is only 5Ghz then the unit will not connect.
See: https://help.fitbit.com/articles/en_US/Help_article/2233/?l=en_US&p=versa&fs=Search&pn=1
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
08-20-2018 07:54
08-20-2018 07:54
