01-13-2019
11:21
15:49
DavideFitbit
01-13-2019
11:21
15:49
DavideFitbit
I am experiencing my battery draining very much since the latest update on or about 1/9/19. I took it off the charger last night, about 1:30. By 7;30 am it was at 64%. I then put it back on the charger and removed it about half an hour later. It was at 92%. Now at 2:00 pm, it has 52%. What is happening? Why is the battery draining so much? This didn’t happen before the update.
01-20-2019 13:19
01-20-2019 13:19
@KtStowers long press the left button on your Versa and make sure Screen Wake is ON.
01-20-2019 13:24
01-20-2019 13:24
Not sure why I would do that, that would make it turn on every time I turn my wrist moves.. Or am I wrong?
@Marrrmaduke wrote:@KtStowers long press the left button on your Versa and make sure Screen Wake is ON.
Best Answer01-22-2019 04:28
01-22-2019 04:28
Best Answer01-22-2019 12:57
01-22-2019 12:57
@KtStowers I thought that's what you wanted as you seemed unhappy with manual tapping:
"but I have to manually tap it to come on".
It doesn't eat much of my battery really. It's the notifications lighting up my Versa like xmas tree that are problematic. But, I live with it.
Best Answer01-23-2019 07:31
01-23-2019 07:31
Hello everyone. Sorry to hear to hear about your Versa's battery draining quickly. For those of you who haven't tried this please clean the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves. If the issue persist or you already tried troubleshooting this issue then let our Support team know so they can further assist you.
Let me know how it goes!
