05-03-2018
04:50
18:31
DavideFitbit
05-03-2018
04:50
18:31
DavideFitbit
As far as I can tell my Fitbit Versa is synced to my iPhone but it is showing the wrong date it is showing a month behind what the actual date is. I have tried nearly everything after researching the net of what to do. I’m just wondering if there is actually a way that works to fix this problem I should I be returning it to place of purchase to get replacement
thanks fir advice
Moderator edit: format
Mine is also saying April 15 and I did a shut down and synced to my phone and it still won’t update. I’ve only had this for 3 days so if this is any indication of how well it works then guess I’ll be returning it
05-15-2018
13:30
18:31
DavideFitbit
05-15-2018
13:30
18:31
DavideFitbit
Figured it out! The clock face needed updated in the app on my phone so once that updated it switched my Versa to the correct date
Thanks for figuring it out!!! That worked for me!!! Whew!!!
Best AnswerI can't seem to find the clock face...could you direct me to it? I really need for this watch to work as I've had a pacemaker put in .. in the last 3 months... SOS folks! I need the date and time to be correct. I've tried the resyncing over and over. I saw this post, but I can't seem to locate the clock on the app.
Thanks!
19:20
18:32
DavideFitbit
11-22-2019
19:20
18:32
DavideFitbit
3 days in my new Versa 2 did same...fixed....great work with tip.
Best AnswerTurunen, I was so unsuccessful with getting a solution, even though this was the third Fitbit I had owned, I purchased an Apple watch 7 months ago. So far I am having better results with the Apple watch. I really liked the Fitbit but with all of them I had band problems which required the additional cost of replacement bands. With my last Fitbit I had to use a rubber band to make sure I did not lose the watch because of the band and then not being able to get the app to synch, I gave up. Do hope Fitbit is more responsive to you and you have better luck than I did with getting resolution to my problems.
JABHarris
