08-06-2018
22:06
09:01
AlejandraFitbit
08-06-2018
22:06
09:01
AlejandraFitbit
Bought a new Fitbit last week and to my surprise the watch does not charge. I even got an extra charger in case the one that came with the watch was faulty but nothing. The watch is faulty. Tried to get help for it but till now, I have received none from Fitbit. Anyone had the same experience with a new product?
Moderator edit: subject
08-06-2018 23:14
08-06-2018 23:14
Have you tried different USB power source such as a wall charger you would use to charge a phone?
Is it showing any signs of life at all?
08-07-2018 00:21
08-07-2018 00:21
Yes, I did. Used both a USB and direct power into the socket and no it doesn't show life.
08-07-2018 00:23
08-07-2018 00:23
I think that sounds like a dead fitbit that needs to be returned / exchanged.
If that's an issue with your retailer then customer support should be able to help via your warranty: contact.fitbit.com
08-07-2018 22:32
08-07-2018 22:32
Yeah looks like a faulty watch. Was really hoping that would not be the case cause I'm not in the US. Thanks though
08-08-2018 09:05
08-08-2018 09:05
A warm welcome to the Community @MashaM and @SteveH thanks for stopping by.
I appreciate all the efforts in trying to fix this issue and would like to know if you followed our friend's recommendation and contacted our support team, have they offer you a solution?
Keep me posted.
