02-17-2020 12:18
02-17-2020 12:18
I've had my fitbit versa since it came out, I ordered it on pre order I loved them that much. However, since the new version came out I've been getting increasing problems with it. Finally I've reached the point its borderline unusable. I can charge it fully and 3 hours later it's gone flat, it doesnt record my heart rate ever, and the screen likes to glitch on and off when it likes. Has anyone else had these problems or knows what I can do about it? I cant afford to buy a new one right now but I cant live without it 😭
02-17-2020 16:39
02-17-2020 16:39
Hi @ChloeSims7 Oh dear, that is sad! Have you tried restarting it several times? If not, give that a try. Also try a Factory reset. If these dont help then contact Support and see if they can help you.
VERSA FACTORY RESET USING BUTTONS
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time, or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
If the device turns on, please go back to the Fitbit app and setup your device back to your account with these steps. Make sure your watch is plugged into a wall plug or a computer, next to the router and that there are no other trackers or devices with Bluetooth on nearby when setting up. Please log into your account, go to account on the upper right corner, there look for "setup a device" and tap on it. Follow the instructions on the screen and let the watch charge for 2 hours.
Helen | Western Australia
