05-31-2020 22:09
05-31-2020 22:09
My fitbit versa left button stopped working on its own. It's just less than a year old. Also, the heart rate is not visible. I started everything from shutting it down to factory reset the watch but nothing would work out. After the factory reset the screen wouldn't change from shortcuts page as left button is not working. Please help!
Best Answer06-01-2020 19:36
06-02-2020 08:12
06-02-2020 08:12
Hi @Niki_M, welcome to our Fitbit Community! Regarding the issues that your Fitbit Versa has experienced with the left button, I appreciate the time spent trying to get this issue resolved before contacting our forums.
In addition to the great information that my friend @Rich_Laue shared, I'd like you to try cleaning around the button with a toothpick in order to remove any dust or moisture that this part of the watch may accumulate.
Let @Rich_Laue and me know how it goes.
06-02-2020 11:01
06-02-2020 11:01
Hi! I have tried shutting it down as well..but it was of no use 😞
Best Answer06-02-2020 11:02
06-02-2020 11:02
I have tried cleaning it as well but the left button won't work :'(
Best Answer07-03-2020 07:33
07-03-2020 07:33
I have the same issue, tried everything...Any suggestion would be appreciated.
