02-12-2019
08:22
05:38
FerdinandFitbit
02-12-2019
08:22
05:38
FerdinandFitbit
Hi all,
I need help urgently, my Fitbit Versa was saying I need to unlock it with my phone, but no matter how I use my phone to reset my password, it doesn't work at all, so I had uninstall my apps and even go to the website and remocemy device hoping that that will work, and I guess I am making things worst, I couldn't pair my device back with it been locked, as when it sent the 4 digit number of my versa, I am unable to view it, please help with this.
Many thanks in advance >.<
Moderator edit: Updated title for clarity
Best Answer@Riuenu removing from your account was a huge mistake. All you can do (beside contacting customer support) is trying to perform 3-button factory reset:
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear.
Hi there @Riuenu, welcome to the Fitbit Community Forums! 🙂
I'm very sorry to hear that your Versa is locked but thanks a lot for all your efforts in trying to get it working again.
Thanks a lot for the great suggestion of giving the Versa a Factory Reset @Marrrmaduke. @Riuenu, were you able to try it out? If so, let us know how it went. If you need more help with this, let me know!
Best AnswerHey! Thanks for the fast reply, as a first timer for this, I had forgotten all about I need to key in the 4 digit that will be shown on clock surface, and has tried for the whole afternoon, and I still can't reset it on the above way you mentioned 😞
Best AnswerHey there, thanks for your reply.
I had tried the metbod of resetting for the whole afternoon, but all I got was blank screen, then back to square again, and also cramped fingers as I had kept trying to reset it, had already contacted the customer service and login a case ID, waiting for their reply... As there isn't a service center in Singapore
