10-08-2018 09:21 - edited 10-08-2018 16:11
I never expect fitbit versa not compatible with Huawei Nova 3i. It works perfectly fine on my iPhone until my recent switch to Huawei. It only sync once when setup was done. Bluetooth connect with Versa but just doesn't sync. My last smart watch for fitbit. Going for Polar smart watch.
10-09-2018 07:16
10-09-2018 07:16
@EdTham Welcome to the Fitbit Community! It's great to have you here! Sorry to hear that your Versa isn't syncing with your Huawei Nova 3i phone. Your phone doesn't show as compatible but you can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, since you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
Let me know how it goes!
Best Answer10-09-2018 07:16
10-09-2018 07:16
Best Answer10-09-2018 07:26
10-09-2018 07:26
Tried all the methods you mentioned and it doesn't help. All the notification doesn't work after the first sync. I have tried all I need to turn on or off or restart and it is all failed. Tried to setup twice as well. Only works to sync up during setup and it doesn't work anymore even the bluetooth still have versa paired.
Best Answer10-09-2018 07:28
10-09-2018 07:28
Tried all the methods you mentioned and it doesn't help. All the notification doesn't work after the first sync. I have tried all I need to turn on or off or restart and all failed. Tried to setup twice as well. Only works to sync up during setup and it doesn't work anymore even the bluetooth still have versa paired
Best Answer10-16-2018 06:24
10-16-2018 06:24
Hi there. Just to confirm.. I'm using nova 2i.. And I'm facing the same problem. My Versa only sync for the first time sync then the second day it went haywire and un sync.. I tried to change account, not event help.. Cannot sync at all.. Have you found solution for this..
Best Answer10-17-2018 04:34
10-17-2018 04:34
No perm solution. However if sometime lucks is on my side. I put the versa into charging station and restart the bluetooth, and sync. Sometimes it works. Sometimes it doesnt.. Quite frustrating. Notification is 100% not working.
Best Answer10-23-2018 22:58 - edited 10-23-2018 23:23
I have the same issue with Nova 3i.
Need to check compatibility before purchase? (compatibility should be a given in today Tech)
Why solution status shown as solved when the compatibility is still an issue?
Best Answer10-23-2018 23:13
10-23-2018 23:13
I was on iPhone and no issue with my fitbit until I changed my mobile.. It is cheaper to change smart watch then a smart phone dude. It is not I bought the fitbit versa then only phone.
11-11-2018 23:41
11-11-2018 23:41
hi there i have the same problem, did the polar tracker work with your phone?
Best Answer12-01-2018 00:30
12-01-2018 00:30
Hey EdTham! Not sure if you ever solved this issue, however I have come across a free app in the Android market which solved all my connectivity issues with my Huawei Nova 3i - it is called Sync Fix for Fitbit and Huawei. Follow all the steps under Permanent Fix, try hard restarting your Fitbit (with holding down the 2 buttons) and restart your phone as well, then go over to the Temporary Fiix tab and just push the Fix now button. All of my issues are now resolved!!! So so happy 😄
12-04-2018 15:00 - edited 12-05-2018 21:22
All so have Huawei nova 3i , which runs android OS 8.1 , won’t sync , hope Fitbit fix this in the fixture , gave Watch to my wife , she has iPhone and loves the watch .
Best Answer12-05-2018 03:55
12-05-2018 03:55
Tryout App - Sync Fix for Fitbit and Huawei (posted by Lena), so far is working on my wife Nova 3i. 10 days free trial, 7.98 for permanent license fee.
Best Answer12-05-2018 21:27
12-05-2018 21:27
Wife has watch now and she is very happy with it , i would buy Fitbit for myself in the future but want this fixed by Fitbit first , good that they is a fix and hope that keeps working for you , thank you .
Best Answer12-13-2018 07:30
12-13-2018 07:30
Same to me.
Previously I had Nokia phone which runs Androidone.
It worked well.
Now I changed to nova 3i and synced only once.
Best Answer12-13-2018 12:19
12-13-2018 12:19
Fitbit state you have to have a android os 5 or better , nova 3i runs os 8.1 , I would be asking Fitbit to fix the problem or get a refund from Fitbit .
01-14-2019 18:57
01-14-2019 18:57
I've tried doing everything suggested but nothing works, will Fitbit add Huawei any time soon???? It's horrible not being able to use the Versa how is meant to be used.
Best Answer01-14-2019 19:53
01-14-2019 19:53
@Kris10_jane Try older Fitbit mobile app build like 2.74.2. Look for an APK file on the internet.
Additional tips if sync issues persist: Go to Fitbit mobile app and remove WIFI if you set it up, sync your Versa. I noticed that it causes issues for me. If you have other Bluetooth devices paired with your phone, forget them. One of them might be causing issues. Also, make sure Always Connected, Keep Alive Widget and All day sync are enabled.
Best Answer01-19-2020 10:22
01-19-2020 10:22
Honestly on my Huawei Nova 5 T works great on all Fitbit Versa apps ... You can add Huawei Nova 5 T to the list. 😉
Best Answer01-23-2020 09:44
01-23-2020 09:44
@kuseskio Welcome to the Fitbit Community! I hope you're doing well! Sorry for the delay in my reply.
Thank you so much for sharing which phone you have and that it is working fine with your Versa. I am sure this will help other members with the same device.
I'll be around.
