I never expect fitbit versa not compatible with Huawei Nova 3i. It works perfectly fine on my iPhone until my recent switch to Huawei. It only sync once when setup was done. Bluetooth connect with Versa but just doesn't sync. My last smart watch for fitbit. Going for Polar smart watch.
@EdTham Welcome to the Fitbit Community! It's great to have you here! Sorry to hear that your Versa isn't syncing with your Huawei Nova 3i phone. Your phone doesn't show as compatible but you can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, since you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
Let me know how it goes!
Best AnswerTried all the methods you mentioned and it doesn't help. All the notification doesn't work after the first sync. I have tried all I need to turn on or off or restart and it is all failed. Tried to setup twice as well. Only works to sync up during setup and it doesn't work anymore even the bluetooth still have versa paired.
Best AnswerTried all the methods you mentioned and it doesn't help. All the notification doesn't work after the first sync. I have tried all I need to turn on or off or restart and all failed. Tried to setup twice as well. Only works to sync up during setup and it doesn't work anymore even the bluetooth still have versa paired
Best AnswerHi there. Just to confirm.. I'm using nova 2i.. And I'm facing the same problem. My Versa only sync for the first time sync then the second day it went haywire and un sync.. I tried to change account, not event help.. Cannot sync at all.. Have you found solution for this..
Best AnswerNo perm solution. However if sometime lucks is on my side. I put the versa into charging station and restart the bluetooth, and sync. Sometimes it works. Sometimes it doesnt.. Quite frustrating. Notification is 100% not working.
Best AnswerI have the same issue with Nova 3i.
Need to check compatibility before purchase? (compatibility should be a given in today Tech)
Why solution status shown as solved when the compatibility is still an issue?
Best AnswerI was on iPhone and no issue with my fitbit until I changed my mobile.. It is cheaper to change smart watch then a smart phone dude. It is not I bought the fitbit versa then only phone.
Hey EdTham! Not sure if you ever solved this issue, however I have come across a free app in the Android market which solved all my connectivity issues with my Huawei Nova 3i - it is called Sync Fix for Fitbit and Huawei. Follow all the steps under Permanent Fix, try hard restarting your Fitbit (with holding down the 2 buttons) and restart your phone as well, then go over to the Temporary Fiix tab and just push the Fix now button. All of my issues are now resolved!!! So so happy 😄
All so have Huawei nova 3i , which runs android OS 8.1 , won’t sync , hope Fitbit fix this in the fixture , gave Watch to my wife , she has iPhone and loves the watch .
Best AnswerTryout App - Sync Fix for Fitbit and Huawei (posted by Lena), so far is working on my wife Nova 3i. 10 days free trial, 7.98 for permanent license fee.
Best AnswerWife has watch now and she is very happy with it , i would buy Fitbit for myself in the future but want this fixed by Fitbit first , good that they is a fix and hope that keeps working for you , thank you .
Best AnswerI've tried doing everything suggested but nothing works, will Fitbit add Huawei any time soon???? It's horrible not being able to use the Versa how is meant to be used.
Best Answer@Kris10_jane Try older Fitbit mobile app build like 2.74.2. Look for an APK file on the internet.
Additional tips if sync issues persist: Go to Fitbit mobile app and remove WIFI if you set it up, sync your Versa. I noticed that it causes issues for me. If you have other Bluetooth devices paired with your phone, forget them. One of them might be causing issues. Also, make sure Always Connected, Keep Alive Widget and All day sync are enabled.
Best AnswerHonestly on my Huawei Nova 5 T works great on all Fitbit Versa apps ... You can add Huawei Nova 5 T to the list. 😉
@kuseskio Welcome to the Fitbit Community! I hope you're doing well! Sorry for the delay in my reply.
Thank you so much for sharing which phone you have and that it is working fine with your Versa. I am sure this will help other members with the same device.
I'll be around.
