07-26-2019
22:38
08:25
JuanJoFitbit
07-26-2019
22:38
08:25
JuanJoFitbit
My fitbit versa will not turn on and hasn’t for months. I tried charging it for hours but when i took it off the charger it would die within minutes. I tried looking on the app to sync but instead it says “searching” with the loading signal spinning constantly. Also on the app it has an X on the battery’s next to my versa so i'm thinking my battery is dead and i need to figure out how to charge or my watch is just not working. I’ve had my watch for over a year and I will be so sad if it’s broken! Someone help!
Moderator edit: format
07-27-2019 08:24
07-27-2019 08:24
@kenziemonson welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since it won't turn on nor charge. I'm afraid that the battery can't be changed since it comes built in.
However, I'd like you to try the troubleshooting steps that are listed in this help article. After this, charge your watch again for 2-3 hours and see if it gets back on track.
Keep me posted on the outcome! ![]()
Best Answer07-27-2019 11:49
07-27-2019 11:49
Best Answer07-30-2019 09:46
07-30-2019 09:46
@kenziemonson I'm sorry for the late response. However, since your Versa got hot after charging it for a few hours, let me go ahead and forward your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
Let me know if you have any questions! ![]()
