06-19-2020
20:04
22:52
RicardoFitbit
06-19-2020
20:04
22:52
RicardoFitbit
My Versa is dead. It will not charge and it will not turn back on. Less than a year old. How do I return it for repair? Starting to think these things are junk. My blaze lasted a little over a year.
06-20-2020 22:51
06-20-2020 22:51
Hi @C_P, welcome to the Community Forums!
Thanks for bringing this to our attention, I understand your frustration. To better assist you with this, can you please let me know if the heart rate sensors are flashing or is your device completely unresponsive? If you haven't already done so, I recommend you to check our help article: Why isn't my battery charging on my Fitbit device? and let me know how it goes. Such article includes a restart process which can be really helpful for this situation
Let me know if you have any additional questions, I'll be here.
Best Answer06-23-2020 10:52
06-23-2020 10:52
It is completely dead.
Best Answer06-23-2020 12:49
06-23-2020 12:49
Thanks for your update @C_P.
To exhaust all the applicable troubleshooting steps to revive your Versa, please follow the next ones to perform a factory reset:
Take in consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Let me know if the Versa responds or if you need further assistance.
Best Answer06-23-2020 14:42
06-23-2020 14:42
I tried that and nothing happens
06-23-2020 14:58
06-23-2020 14:58
Welcome aboard @Iloewen14.
Thanks for troubleshooting your device with me. Can you please specify which steps you already tried so we can move forward?
I'll be waiting for your reply.
Best Answer06-23-2020 15:02
06-23-2020 15:02
1. Pushed power button multiple times. To see if it would respond.
2. Cleaned the charging port. Tried a different power source.
3. Cleaned the Versa.
4. Checked for a light on the bottom and there is nothing.
06-23-2020 15:15
06-23-2020 15:15
My versa is also dead only 1yr old. I tried regular reset and factory reset and nothing!
Best Answer06-23-2020 15:16
06-23-2020 15:16
Tried this and nothing happened. Are these under warranty?
Best Answer06-23-2020 15:33
06-23-2020 15:33
Welcome aboard @Cm2tlavoie. Thanks for your reply @Iloewen14.
@Iloewen14 Your effort troubleshooting this situation before to posting is appreciated. I noticed that a factory reset procedure wasn't mentioned in your post, please try the steps from my previous post and let me know if the issue persists.
@Cm2tlavoie Thanks for your post. If you haven't already done so, I recommend you to check our help article: Why isn't my battery charging on my Fitbit device? and let me know if the issue persists. Also, for any warranty-related inquiry, please check our policies here.
I'll be here, ask me any additional questions you may have.
Best Answer06-23-2020 16:33
06-23-2020 16:33
I tried the factory reset. Is there warranty on these?
Best Answer06-23-2020 17:00
06-23-2020 17:00
I'm having the same issue. My battery went dead on Saturday. I placed on charger. It did not charge.
I cleaned all connections. Tried different outlets. I ordered a new charger just in case. New charger came in. Still nothing. Dead. I have had it for I you and a couple of weeks. Disappointed that I paid 175.00 for something that only lasted a year.
06-24-2020 09:35
06-24-2020 09:35
It is dead. I have attempted all of the known trouble shooting fixes.
