10-19-2019
12:27
12:34
DavideFitbit
10-19-2019
12:27
12:34
DavideFitbit
I just got a Versa and went through all the steps but I am only getting calls not msgs. It says a restart to the phone is needed which I done numerous times. I can't actually restart my phone only reboot which I would assume is the same but the fact I am receiving calls should mean I set it up right I think
Moderator edit: format
10-19-2019 13:45
10-19-2019 13:45
Hi @Cos1 , if you are using by nay chance and iPhone and upgraded to iOS 13, see the message on top of the Customer Support Site. Regards kuzibri
10-19-2019 13:48
10-19-2019 13:48
Im using android so it shouldn't affect me but I was onto chat and they said that it is a possibility
10-19-2019 13:52
10-19-2019 13:52
Make sure message permissions are turned on in the android application settings for the Fitbit app and that you have set a default message receiving app.
