06-09-2018
09:46
11:45
DavideFitbit
06-09-2018
09:46
11:45
DavideFitbit
Does the Fitbit Versa have a sleep mode? Not the sleep tracking. Somewhere, where I can switch off the screen light so it doesn’t turn on every time a turn in my sleep.
Moderator edit: format
To my knowledge the FitBit Versa does not have a sleep mode. But you can turn down the brightness on the FitBit Versa in settings in the watch. Also you can make the screen turn off after a couple of seconds in settings on the watch.
Best AnswerSleep mode is not on the Fitbit Versa Lite (I have one) but it says that it is in the manual. Go figure.
Best AnswerThe Versa Lite does have sleep mode, I am not sure if it's available in original Versa, but it should be, because as I know both devices have the same software.
Be sure that you have the latest version of firmware update, check the latest version of firmware update here.
https://help.fitbit.com/articles/en_US/Help_article/1372.htm
You can find sleep mode in settings and there you can also customize your sleeping hours. Or you can just easily turn sleep mode by control center.
To access the control center on your watch, swipe down from the top of your screen. After your notifications appear, swipe down again to open the control center, and there you can find sleep mode tile.
