01-03-2019 15:17
01-03-2019 15:17
Hi,
So I managed to set up my Versa, after a lot of failures. But now every time I try change an app or clock Facebook it says it can’t connect. It won’t connect to wifi either. It won’t show notifications from my phone either.
is this a common issue? Because I want to just return it at this point.
Ive tried all the resetting options, made sure everything is set, no other Bluetooth devices.
i am just extremely frustrated.
01-04-2019 16:17
01-04-2019 16:17
@Coccorosa Try this:
If you have Wifi set up, go to Fitbit mobile app and remove it, then sync your Versa. I noticed that it causes issues for me. If you have other Bluetooth devices paired with your phone, forget them. One of them might be causing issues. Also, make sure All day sync is enabled.
01-04-2019 16:17
01-04-2019 16:17
01-11-2019 03:48
01-11-2019 03:48
I feel like I constantly have to do some of these solutions every time I want to to just sync. Good suggestions though! They do work, thank you
01-11-2019 03:58
01-11-2019 03:58
@Coccorosa I know it's a pain but I hope there will be an update to fitbit app soon that would at least address some of the issues that arose after the recent iOS update. Good luck!
