02-24-2020
20:47
04:23
JuanJoFitbit
02-24-2020
20:47
04:23
JuanJoFitbit
Hi all,
I got my Versa in July 2018 and it worked perfectly until a few months ago. I started having issues with bad heart rate readings, and now I am having issues with battery life. I need to charge the watch a few times a day and it often dies on me while I’m sleeping. I have also experienced a couple of times my watch not turning on or seeming to connect when placed in the charger. I have tried all of the restart options I’ve seen in the forum but this time nothing is working. Is it just dead or is there hope of reviving it?
02-25-2020 04:22
02-25-2020 04:22
@KaraEJ999, welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since it experienced battery draining issues and now it won't turn on. By the way, thank you for troubleshooting this issue before contacting our forums.
I would like to know if your Versa vibrates when you put it on the charger.
In the meantime, try the troubleshooting steps that are listed in this help article. This article contains the restart process but you can skip them and proceed with the rest.
Keep me posted on the outcome.
Best Answer02-25-2020 21:38
02-25-2020 21:38
Thanks for the reply.
No luck. I ran through the steps in the link to no avail. The watch does not vibrate when placed in the charger.
Best Answer02-29-2020 09:07
02-29-2020 09:07
@KaraEJ999, I'm sorry for the late response. However, I appreciate the time you spent trying the recommended troubleshooting steps.
Since the issue persists, let me go ahead and forward your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
I'll be around if any questions arises.
