11-26-2019 14:34
11-26-2019 14:34
What do. I do when it says reset failed
the screen was not responding to anything it was stuck on the face clock so I reset my Fitbit
11-26-2019 15:20 - edited 11-26-2019 15:22
Try a Factory Reset by swiping left to Settings, then About, and then Factory Reset. I'm assuming the reset you referred to is a Restart.
Best Answer11-26-2019 15:24
11-26-2019 15:24
How Can I do that when it’s stuck on reset failed
Best Answer11-26-2019 15:29
11-26-2019 15:29
You are right. My bad! Contact Customer Support.
11-26-2019 15:29
ive reset it a few times now All it says: Reset failed your data was not cleared. Please try again
Best Answer11-26-2019 15:31
11-26-2019 15:31
Yes it’s a bit irritating and I’m waiting for them to reply
