03-20-2020 16:52
03-20-2020 16:52
Hoping for some help. My fitbit versa (bought in January 2019) has started showing a double screen display that vibrates. I didn't do anything different to normal and don't wear it in water but one night it was working and the next morning it was showing this. I tried resetting it with no luck. I've emailed Fitbit support with a video and photo but the reply I got was to try resetting it again and doing a factory reset.
Then when I let them know that these didn't work they replied "Unfortunately, we have exhausted all troubleshooting steps and your Versa still has a corrupted display. Furthermore, your product doesn’t meet the replacement requirements of our warranty policy."
I'm really disappointed that a $300 device doesn't last much longer than a year with good care and no explanation of how the issue started.
I am hoping someone else out there has had the same issue and has some sort of solution.
03-26-2020 11:31
03-26-2020 11:31
Best Answer03-20-2020 18:16
03-20-2020 18:16
@SarahJen I am trully sorry to hear that. 😞 Were you able to perform a factory reset successfully like in wiping the device and setting it up again? If the problem still persists even after several successful factory resets, I am afraid there's not much you can do. Unfortunately, Fitbits are not exactly serviceable... 😞
Best Answer03-24-2020 07:16
03-24-2020 07:16
Thanks for the reply. Unfortunately no difference with the factory resets.
I think I'll be changing brands away from fitbit with my next purchase as it's very disappointing for a watch that's 14 months old.
Best Answer03-24-2020 09:28
03-24-2020 09:28
@SarahJen And you're not in Europe (EU has mandatory warranty of 2 years) or don't have an extended warranty from the retailer? I would still reach out to Customer Support because it is obviously a hardware issue. The prouct should not fall apart and I would hazard a guess it's defective unit as I had several Fitbits (Versa, Versa 2) and they did not fall apart. I am trully sorry really. 😞
Best Answer03-24-2020 15:40
03-24-2020 15:40
@Marrrmaduke Thanks for the reply. Here in Aus they do have the 2 year warranty but when I've contacted the they said that it isn't covered 😔
Best Answer03-24-2020 18:25
03-24-2020 18:25
@SarahJen Are you still within 2 years?
Best Answer03-24-2020 20:01
03-24-2020 20:01
Hi @Marrrmaduke yes I am
Best Answer03-26-2020 11:31
03-26-2020 11:31
Best Answer03-26-2020 16:40
03-26-2020 16:40
Thank you @Marrrmaduke I will definitely follow up with them again!
Best Answer03-27-2020 10:26
03-27-2020 10:26
@SarahJen Please do. You purchased the tracker after the court decision in 2018 so you are entitled to 2 years warranty. I did flag your post for Customer Assistance but given the current situation reply here might take a while.
Best Answer03-30-2020 03:11
03-30-2020 03:11
Thanks @Marrrmaduke after contacting them again and explaining a second time they have allowed me to send my faulty fitbit back and hopefully I will get a replacement soon!
03-30-2020 07:23
03-30-2020 07:23
@SarahJen good good! 😄
