01-01-2019 07:57
01-01-2019 07:57
OK I'm having a bit of a problem sorting my versa out. Firstly, I went for a 5k run this morning but cannot see the map I ran anywhere? How do I set GPS? Also, on my last watch, I liked the fact that it vibrated when I reached a mile and also when my heart rate got too high, how do I do this on my versa? I'm using an Android app not ios xx
Best Answer01-01-2019 08:43
01-01-2019 08:43
Hi, did you have your phone with you when you were running? This is mandatory, cause the Versa does not have GPS on it's own, but usesthe GPS of your Phone. Regarding HR, as fa as I know, the Versa does not vibrate when your HR is too high. Regarding vibrating when you've reached a mile, this will also not happen. what you can do is set in the Today screen of your Versa (swipe up from the bottom of your watch and you will see steps etc, scroll doen to settings and you will see more activities to be tracked and enable the steps per hour.
