06-12-2021 05:12
06-12-2021 05:12
Fitbit logo is stuck on. Screen will turn white when dimmed.it will show the previous application behind the screen. Will not measure heart rate or steps
06-12-2021 12:31
06-12-2021 12:31
Hi @Lovelypencil152,
This may be a hard pill to swallow, but you may need to do a factory reset. If you have the Versa 2, 3, or Lite, all you need to do is hold down the button/sensor on the right for about 20 seconds. If you have the Versa 1, you need to hold down all 3 buttons on the device for about 20 seconds. Then follow the setup process you used to set up the Versa with your account initially.
one cruise ship at a time!
Best Answer06-12-2021 12:31
06-12-2021 12:31
Best Answer06-13-2021 02:53
06-13-2021 02:53
thank you!
Best Answer01-02-2023 09:19
01-02-2023 09:19
It didn't work by the way. I'll probably get a new watch.
