01-29-2019 12:36
01-29-2019 12:36
Hi,
I have had my versa 2 months and today my screen started acting very bizarrely (I have tried to upload a photo, but it's not giving me option to select from gallery). It's like it's freezing and image is stuttering... I cannot use it. It still buzzes when I get messages or calls, but the screen just won't work.
I have tried the resetting but it's not working.
Hoping someone can help? Thank you in advance.
Best Answer01-29-2019 13:15
01-29-2019 13:15
Hi, according to the fact that you tried to upload a photo on your display, I'm convinced that you're using a Third Party Clock Face. Unfortunately this seems to be incompatible with the new Firmware Version. If you're still able to change Clock faces within the Fitbit app, install one of Fitbit itself, preferably "Light" and restart your Versa and see if the problem is solved. Keep me posted in this.
Best Answer01-29-2019 13:21
01-29-2019 13:21
Best Answer01-29-2019 13:26
01-29-2019 13:26
Hi, sorry if I misunderstood you. Try restarting your Versa several times and see it that solves your problem. If that does not solve it, contact Customer Support about your problem.
Best Answer01-29-2019 13:31
01-29-2019 13:31
