Fitbit won't select
Fitbit won't allow for setting selection or other options. Tried reset and that isn't working either.
1 REPLY 1
Hello   Welcome to our community forums!
Thank you for trying a restart before contacting us.
Thank you for sharing the situation.  It will be a pleasure to assist you.
In order to provide you correct support I ask you for more details about the issue:
  • Are you seeing any error messages on your Fitbit?
  • Can you swipe through the menu on your screen?
In the meantime I suggest you change the clockface in your Fitbit:
  1. With your device nearby, in the Fitbit app, tap the Today tab / devices icon / your device.
  2. Tap Gallery / Clocks tab.
  3. Browse the available clock faces. Tap the clock face you want / Install.
