05-04-2019 10:21
05-04-2019 10:21
My Fitbit keeps vibrating and showing the notifications bar. I cannot use the side buttons to even make it turn off. It’s just constantly rolling through different screens
05-04-2019 12:43
05-04-2019 12:43
Hi, are you also not able to perform a Factory reset, either by going to the settings on your Versa, press it, scroll down to device info, press that too and scroll down to factory reset and press it, or by using the three buttons method: press all three buttons together untill you see the Fitbit logo appearing and release only the right lower button. Keep the other two pressed untill you feel a strong vibration, meaning that the FR process has started. After a while, which may take seconds, you will see the Fitbit logo appearing again meaning that your device is restarting. If none of this is possible, contact Customer Support about this issue.
05-08-2019 09:51
05-08-2019 09:51
@Drsjms2 Welcome to our Fitbit Community! I'm sorry for the late response. However, I'd like to follow up on the issue that your Versa is experiencing since it keeps vibrating.
In addition to the information that shared @SunsetRunner, please have your Versa's battery to drain completely. After this, charge it for 2-3 hours and see if the issue gets fixed.
Keep @SunsetRunner and me posted on the outcome! ![]()
09-15-2019 16:19
09-15-2019 16:19
My fitbit is doing the same thing and will not stop. It started last night while I was sleeping. It keeps rolling through the notifications and different activities as if I was selecting them. I did a factory reset and nothing changed. The side buttons do not respond.
Best Answer09-16-2019 10:09
09-16-2019 10:09
@Hldc0703 thank you for joining us in this thread and our Fitbit Community! Thank you for trying a factory reset before contacting our forums in order to fix the display issues.
I would like you to try another method to factory reset your watch. To do so, open the Settings app > About > Factory Reset or Clear User Data. Please sync your Versa before this in order to avoid losing current data.
Once you've done this, try changing the clock face to one developed by Fitbit and see if the issue gets fixed.
Let me know how it goes! 😀
Best Answer11-27-2019 12:33
11-27-2019 12:33
My Fitbit has begun doing the same. I have gone through all the steps that have been listed in this thread and it is still doing it. My Fitbit is exactly one year old.
Best Answer12-02-2019 03:21
12-02-2019 03:21
@Cospie, I'm so sorry for the late response. However, let me welcome you to our Fitbit Community.
Regarding the vibration issues that your Versa was experiencing, I appreciate the time spent trying the recommended troubleshooting steps.
I was able to get in touch with our Support team and was told that they assisted you via chat. I'm so glad to hear that a solution was provided and you will be back on track soon.
As a side note, I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community more often.
Best Answer06-16-2020 20:19
06-16-2020 20:19
What was the fix? Mine has been doing that and then the screen went blank. Although it’s still vibrating off and on.
Best Answer08-24-2020 11:09
08-24-2020 11:09
Hi @DebRuss86, thank you for joining us in this thread and our Fitbit Community. Since your Versa is still vibrating off and on, I'd like you to try a factory reset. To do so on your device, follow the steps below:
Keep me posted on the outcome.
Best Answer01-30-2022 11:11
01-30-2022 11:11
Hi, my versa 2 began constantly vibrating whilst it was charging. I did a reset 3 times but as soon as it’s back on it starts again. I have also changed the clock face but no joy. Please help it’s driving me mad!
Thanks 😊
