01-29-2020 07:55
01-29-2020 07:55
Having trouble fitting replacement strap(supplied with newly purchased Fitbit) which is the heavy plastic one has it seems to thick for the device. Currently using the thinning "fabric" one but thought l wanted a change. Can any one help with advice. Many thanks in advance.
01-29-2020 20:14
01-29-2020 20:14
I also found it difficult. BTW all Versa straps are interchangeable.
Best Answer01-29-2020 20:14
01-29-2020 20:14
