12-30-2018 14:06
12-30-2018 14:06
Home screen / clock screen flashes continuously but is ok on other menu screens on my Versa . How can I get it to stop? I’ve reset a number of times.
12-30-2018 14:19
12-30-2018 14:19
@Andysaxton Are you using a 3rd party clockface? Try changing a clockface with a reboot of your tracker in-between.
12-30-2018 14:19
12-30-2018 14:19
03-10-2019 15:41
03-10-2019 15:41
I have the same problem with my six month old versa the clock screen is flashing did you get a solution?
Best Answer03-11-2019 08:55
03-11-2019 08:55
@Foncegirl10 Try changing a clockface to one of the Fitbit originals.
03-14-2019 15:25
03-14-2019 15:25
This worked for me right away. Thank you!
04-14-2019 19:40
04-14-2019 19:40
worked instantly for me. Thank you!
Best Answer05-22-2019 10:22
05-22-2019 10:22
I've tried changing the clock face, turning off and back on, and a factory reset. The clock face flashes 10 to 15 times, goes to my 'today' screen and then eventually stops. Unfortunately I've had this for almost a year, so it is out of warranty. I'm frustrated with not being able to use my versa all day long. Before the flashing issue, I could go almost a week between charging.
05-22-2019 14:00
05-22-2019 14:00
@Cinnnnie This obviously should not happen. I flagged your post for Customer Support assistance. Let's hope they can work something out.
Best Answer05-22-2019 16:04
05-22-2019 16:04
@Andysaxton @Foncegirl10 @EStack @switz76 @Cinnnnie Welcome and thank you for visiting the Fitbit Community.
I'm sorry to hear that you are experiencing difficulties with the screen of your Fitbit Versa.
@EStack @switz76 Thank you for reporting the issue has been resolved.
@Cinnnnie I created a case with Customer Support to evaluate your situation. Please check your inbox on the next days. They will let you know how to proceed.
@Marrrmaduke Thanks for your support.
If you have any question, please don't hesitate to contact us at any time.
Best Answer05-22-2019 19:53
05-22-2019 19:53
@EdsonFitbit as always,thank you for your prompt reply! 😊
06-02-2019 07:13
06-02-2019 07:13
Was this killing your battery fast
Best Answer09-25-2019 07:47
09-25-2019 07:47
I just rebooted my fitbit watch and its back to normal know i am so happy its fixed.
Best Answer10-21-2019 14:50
10-21-2019 14:50
I am having similar issues with my Versa. The screen is always active with the menus flashing and the vibration going off each time the screen flashes. It has only started happening in the last week. I've reset everything I can find, let it run flat, charged it, updated it and it's still doing it. I can no longer wear it as it is annoying. It's not 12 months old yet.
10-27-2019 06:51
10-27-2019 06:51
This is happening to mine just like you described. It was fine until I tried a third party face, but j didnt like it. I then tried a Fitbit face and it started happening.
Best Answer04-15-2020 19:34
04-15-2020 19:34
I am having the same problem.
Best Answer04-15-2020 19:35
04-15-2020 19:35
I am having this same problem.
04-22-2020 11:06
04-22-2020 11:06
It has been a while, but I think all I had to do was restart the FitBit or re-sync it with my computer. It was definitely a pain! I think worst case scenario is completely deleting the fitbit from whatever device it talks to and basically start fresh as if you had just opened the box.
Best Answer05-06-2020 07:24
05-06-2020 07:24
Hi how do u escalate to support as my versa keeps flashing and wont connect to wifi
Best Answer05-12-2020 08:28
05-12-2020 08:28
Am having the same issue all of a sudden in the last 3 days. Screen keeps alternating between exercise shortcuts and notifications. I have reset, changed clockface, etc. it is 2 years old.
