01-22-2019 23:51
01-22-2019 23:51
Hi there,
My Fitbit Versa just vibrated on my arm and when I looked down, it was flashing the blue Fitbit Logo.
I've tried to put it on the charger, but it is still flashing.
What does this mean? And how do I fix the problem?
Best Answer01-23-2019 04:42
01-23-2019 04:42
Yes! The same thing is happening to mine this morning. I would love to know what’s wrong or how to fix it!
Best Answer01-23-2019 04:51
01-23-2019 04:51
Mine did that also so I went into app on my phone and it did an update. Took ages and now it has locked me out and won’t accept my pin code. I think I will have to delete it and reload unfortunately.
Best Answer01-23-2019 05:20
01-23-2019 05:20
It means your versa is restarting itself.
Best Answer01-23-2019 05:44
01-23-2019 05:44
Even if its been doing it for over an hour now? Will it just stop on it’s own?
Best Answer01-23-2019 06:20
01-23-2019 06:20
Try to do a factory reset, shut down and unpair and pair back your Versa. If it's still restarting, I suggest you contact customer support like I did. Mine was defective.
Best Answer01-23-2019 06:28
01-23-2019 06:28
Thanks! I contacted support and they walked me through it. Seems to be working fine now after restarting the versa & iphone, then pairing it again.
Best Answer01-24-2019 06:03
01-24-2019 06:03
Best Answer01-24-2019 15:19
01-24-2019 15:19
Best Answer01-24-2019 18:17
01-24-2019 18:17
Thanks all.
I re-set and everything is all good now!
