04-20-2018
13:46
08:26
LucyAP
04-20-2018
13:46
08:26
LucyAP
On the home page it say I have 1500 calories left in my budget but if I go to my food log it says i have 600 left in my budget I don't understand. Can anyone help?
04-21-2018 08:24
04-21-2018 08:24
Welcome to the Forums @Kurlz! I appreciate that you have describe the issue you are experiencing with your calories.
Since your food plan setting is set to "Personalized," which uses your past activity history to estimate your calorie burn for the day and increases or decreases that number if you're more or less active then usual throughout the day. Since your calorie budget is calculated based on your daily calorie burn, your calorie budget will fluctuate.
In other words, while your calorie budget resets to a certain number at the start of each day, as the day progresses your calorie budget fluctuates based on your activity, increasing when it projects you will exceed your average daily calorie burn (for example if you go on a big run in the morning) and decreasing/normalizing when your activity slows later on. To read more about this, take a look a the help article How do I track my food with Fitbit?
I hope this helps, keep me posted! 😉
04-22-2018
20:47
09:48
LucyAP
04-22-2018
20:47
09:48
LucyAP
I understand that but on the home page it says something different than on the food page
Moderator edit: format
04-26-2018 10:07
04-26-2018 10:07
Thanks for the update @Kurlz and for the pictures! At the moment this is a known issue by our engineering team and they are working to find a fix for this. We are really sorry for the inconvenience, and we hope to get you back on track soon.
Catch you later!
